Andorra
Radoslaw1991
Ee is a bunch of nonsers honestly. They knows that there is phones problem in Andorra and no f's given at all.
9 REPLIES 9
Mustrum
@Radoslaw1991   what problems are you having?
I have been there many times, but tend to use Wi-Fi which is plentiful due to the extra costs - that said, never had an issue with mobile signal.
No Internet,   no data , no calls
@Radoslaw1991   did it work ok in France/Spain before doning to Andorra?
Radoslaw1991
Yes it worked all fine.
It worked all fine until Andorra
Christopher_G
Have you tried manually searching for an available network, @Radoslaw1991?
Northerner
Hi @Radoslaw1991
Are you pay monthly or PAYG?
When were you last in the UK?
Andorra wouldn't be in the EU roaming like France/Spain.
No but I was teying to fillow instructions and buy a addone wothout success
Does your phone show a connection to a local network in Andorra? If you have no network coverage, it would cause these symptoms.
If roaming has worked in other countries, then self-evidently it's active and EE's part of the setup is done. Toggling flight mode and manually selecting alternative local networks often resolves these issues.
