05-04-2021 05:13 PM
Hi there,
I just bought a sim card, topped up with credit, but cannot receive or make phone calls, to Spanish phone numbers or UK numbers. Is there any solution to activate my roaming_
Many Thanks in advance
05-04-2021 06:52 PM
Where you buy it? Did you use that PAYG SIM for making calls or texts in UK before you left to go abroad? EE PAYG SIMs need 1st activating on EE's home UK network. If it wasn't you can't now use it until you return to UK.
05-04-2021 06:56 PM
@Manolecho76 you can’t activate a EE Sim card on a roaming network it has to be done within the UK first once it works in the UK you can then use it abroad. Nothing can be done to rectify this while not in the UK.
