on 22-03-2023 11:46 AM
I am going to Spain next week. I am new to EE will my phone automatically work?
Solved! Go to Solution.
on 22-03-2023 01:34 PM
@GemS811 : You may use your usual UK allowances in the EU with up to 50 GB (contract) or 25 GB (PAYG) data per billing month if you have more. If on contract & your contract started after 07/07/2021 there'll be a £2 / day charge for using your UK allowances in EU or alternatively you may buy the Roam Abroad Pass for £10 / month charged pro-rata. There are no extra roaming charges for PAYG.
If you are on contract, remember to text ROAMING to 150 before you leave UK to ensure roaming is enabled on your account.
on 22-03-2023 12:13 PM
Hi @GemS811
Likely not. You'll need to text ROAMING to 150 to check.
