Abroad
Master4
Hello
I am currently abroad and I am unable to receive or make calls and send messages. Please can someone help me please
@Master4 : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
