11-03-2026 06:13 PM - last edited on 11-03-2026 06:19 PM by Peter_W
The EE network has been a joke for a month now!!! There are constant
problems. Connection issues, the internet works like it did 10 years ago
(3G connection), my friends are also having problems with this network.
This is happening across the whole of Coventry.
12-03-2026 09:54 AM
HI @prophilips1
Sorry to hear you’re facing problems with signal.
The first step to try is restarting your device.
You can check coverage and network status at Check mobile coverage where you can also report any issues you are facing, as well as sign up for updates on any known issues that may be going on.
Ali
11-03-2026 06:16 PM
Post moved to new thread.
What are the "connection issues" you're having? Can you be more specific - calls not connecting? Mobile data not loading? Phone losing coverage in locations that others have it?
3G was switched off nationally in 2024.
11-03-2026 06:32 PM
11-03-2026 07:57 PM
So data speed issues then. Interestingly, the thread you'd originally added to was discussing the potential local issues with 4G2100, but you refer to having 5G so you'd be on the opposite side of the fence of B1 has been locally refarmed to N1.
Which bands & carriers are you seeing locally?
11-03-2026 08:14 PM
11-03-2026 10:25 PM
@prophilips1 wrote:
Today, there are general problems with BTS in Coventry.
Such as?
11-03-2026 10:47 PM
12-03-2026 09:54 AM
HI @prophilips1
Ali
