no signal
alexuta
I don't have signal and the calls are failed, i don't know what to do anymore i think i will change the provider . TERRIBLE!!!!!
alexuta
I HAVE THE SAME PROBLEM BUT THEY SAID THE SIGNAL IS GOOD IN MY AREA AND I STIL DON;T KNOW WHAT TO DO !
There's no need to shout - typing in all capitals on the internet is generally considered to be doing so.
You can check for predicted coverage in any location using "check coverage" on https://coverage.ee.co.uk/coverage/ee
Temporary service-affecting issues are listed under "check status" - all networks have these from time-to-time.
Eddy2760
Expert Contributor
Expert Contributor
Hey 👋… yeah signal indoors and sometimes in rural places the signal for most networks can be problematic.
If you have broadband/fiber, have you tried to activating WiFi calling on your mobile?
Wi-Fi calling works through transmitting the same cellular data packets as Wi-Fi VoIP through a Wi-Fi connection and across the internet. From the internet, data is passed to the cellular network and then back to the answering party.
It can improve call quality, but Wi-Fi calling can also extend your phone's battery life, as weak cell signals cause your phone to use more power to boost the connection.
hope this helps 🙂
Eddy
