30-10-2024 05:59 PM
my current plan on an iphone 14 pro max is 4G SIM Unlimited Plan £25 / £45.84 Monthly how can I upgrade this so I can connect to 5g networks
31-10-2024 08:35 AM
Good morning @enemsea.
Welcome to the EE Community 😊
We've offered 5G as standard on plans for quite a while now, so chances are if you're on a 4G only plan you should be ready to upgrade now.
Can you remember when it was that you took this plan out, and if you check out the EE App, or log in to your account online, does this show you upgrade options?
Peter
31-10-2024 08:35 AM
Peter
