Uncapped speeds
123Jason
I decided to treat myself to the 16 pro max with uncapped speeds.
Even at home in Birmingham City Centre it was just pushing 100 mbs which I’d get 150 mbs on my 7 year old XS Max.
Anyway I’ve now moved back to Newcastle and upstairs at home I’m getting 100 mbs but downstairs where I work from home it’s 10 mbs max but generally around 2 mbs
My SIM only contact goes up to £50 end of March I feel violated.
DoctorBlue52
Hi!
What plan do you have? The no frills plan is capped at 10mbs, it sacrifices speed for price but if you spend most of the time connected to wifi then you won't really notice!  🙂
