Tech support
Jddy
How about this from the uk no1
new visual contact method
when you call from a mobile that works to tell them about a mobile that’s not working they tell you the mobile you are on is fine ?
no option to tell them you are calling about another number
then to make it worse they send a text asking you to text them back if you can’t text
wow
amazing design for a smart piece of software
congrats
@Jddy   Why are you using a service that’s for the device that you are actually using at that time.    Why are you not speaking to customer services about the device that actually has the issue.
Cause it doesn’t give you that option
the connection issue was on another phone of mine currently on hols with my daughter
@Jddy   You need to call +44 7953 966 250.  Standard roaming rates apply to your location.
