Signal issues
MRSMT1
I’m new to EE after being with O2 network for years, I am beginning to regret my decision as the signal is very poor and at times I can’t get a connection at all, I’m missing important calls
Linzi_H
Hi @MRSMT1
Welcome to the Community.
I'm disappointed to hear that we've left you feeling this way.
I would advise contacting our Technical Support Team so they can look into this in closer detail. They'll be able to run some further checks on any issues you're facing and give you the best advice.
Linzi
@MRSMT1  Did you not test the signal with a PAYG sim before changing provider?     All networks have good and poor coverage areas.   WiFi calling can help if you have a WiFi network.
Linzi_H
Hi @MRSMT1
Linzi
ee_user14
Skilled Contributor
Skilled Contributor
Out of interest, do miss unimportant calls as well? Sorry, I've often thought this a slightly odd expression.
Seriously though - compare the coverage you're getting, with that predicted by the online coverage map.. is it about right?
