Re: internet speed
Atlas20
Hi
I switched to sim only 5G 100mbps max speed
Sadly the best speed I can get is 25mbps, knowing I used to get 180 in our street.
That's 75% slower
I'm ending my contract if they don't fix the problem .
@Atlas20  Have a look at THIS  and click the check status tab.  There could be a network issue in your area.
10 REPLIES 10
What did you switch to your current plan from?
Was it a 4G-plan or another 5G-enabled one?
I switched from 5G with phone contract & no maximum speed.
@Atlas20   If you look at your plan type via your EE account. Does it says it’s an essential plan or a no frills plan ?
My Plan is Essential SIM 125GB £25 12m
Many thanks
Network is good 👍
James_B
EE Community Manager
Hi @Atlas20,
What does it report if you select the 'check status' option?
It's showing excellent network
James_B
Hi @Atlas20,
That sounds like you've selected the 'Check coverage' option again.
Please try 'check status'. If it doesn't report any issues, you'll see an option to report a problem.
Hope this helps.
