on 11-06-2023 06:30 PM
Hello - I’m having exactly the same problem around Sherborne in Dorset - it’s absolutely useless around the area where I live - used to be great but is now almost unusable- where are you located??
on 11-06-2023 10:28 PM
What's the issue you're having around Sherborne?
on 12-06-2023 06:38 AM
In our local area it often sounds like the person on the other end is in a barrel of water 💦! I’ve spoken with a few people who are also with ee and they’ve been having the same issue- also 4g - although still working seems less reliable atm .
on 12-06-2023 07:15 AM
Morning @Vinnie6
Welcome to the community.
Could you check your postcode on our coverage checker and hit 'check status' please? It will let you know if we're aware of any problems and allow you to report one if we're not.
Thanks 🙂
Leanne
