24-01-2023 02:28 PM
in my postcode area (TF9) the signal is always bad.... indoors anywhere in my town you struggle to get any signal at all. in my home i very rarely can take a call unless i use whatsapp or messenger. most times my phone will ping when i go upstairs to tell me i have a missed call. . the EE mast is less than half a mile away on top of a former water tower..... i can see this from my back garden . EE tells me there is a second mast somewhere in the area , but they won't tell you where..
EE coverage checker says "you can expect good coverage indoors and outdoors" in my area...... i think not!
i have been disatisfied with the signal/service for years, but speaking to users of other services i dont think they are any better.. i think its just a case of there isnt a lot of money to be made from small towns, so they arent going to spend the money to improve the service.
11-02-2023 09:15 AM
yes i have wifi. by wifi calling do you mean use whatsapp or messenger? fine except that's no good indoors anywhere else in the town..... no signal indoors...
11-02-2023 09:18 AM
Thanks for coming back to us.
If you would like to get the signal problems looked into, I would suggest getting in touch with our tech gurus.
They will give you an update after checking the area.
11-02-2023 05:50 PM
Do you know any friends or relatives who use EE - do they have the same problems in the same location? If they do, that's good evidence of a network issue, but if not there may be a fault with your phone.
Apps such as WhatsApp & Messenger are just that - apps. WiFi-calling enables you to make & receive calls using your phone's native dialler, and send & receive text messages - all as normal without any need for mobile coverage.
WhatsApp & Messenger only allow you to communicate with other app users, but calls & texts made or received via WiFi-calling are sent & dialled entirely as normal, and will seamlessly swap between WiFi & 4G-voice carriers.
