on 10-02-2025 01:01 AM
Signal so weak in the PL4 area of Plymouth i thought i was on dial up
on 10-02-2025 08:11 AM
Sounds like you're reporting an issue with poor data speeds, in an area where you've previously had better service?
The "check status" option on the webtool is the recommended first-line check here - https://ee.co.uk/help/mobile-coverage-checker - then either "keep me posted" or "report a problem" depending on the outcome.
