No signal
Raymond9
I have had no phone or data signal for a couple of days. Network coverage is good in my area. I have turned my phone off and on, turned airplane mode on and off again and I removed and replaced my SIM card all to no avail. I can’t get through on the phone and would appreciate some advice.
Hi there
Thank you for your reply. I phoned EE in the end and they said to call into a store to replace the SIM card. I did that and my problem is solved. Thank you.
Sent from Outlook for iOS<>
6 REPLIES 6
Schockwave
Hello @Raymond9 ,
Welcome to the community,
Have you checked here;
https://coverage.ee.co.uk/coverage/ee
Also, is this happening in one area or everywhere you go?
Hi there, thanks, I’ve checked that and coverage is good. It’s happening everywhere.
@Raymond9 , it looks like either your SIM card has developed a fault or your phone.
Are you on a contract or pay as you go?
If pay as you go, how long is it since you used your phone/sim card?
The coverage checker tool has two options..
1: "Check coverage" predicts normal service in your location - it sounds like you've used this option.
2: "Check status" searches for known faults & issues - did you use this?
The status check also allows reporting of issues not yet flagged.
Hi there
Leanne_T
Thanks for coming back and letting us know @Raymond9
