13-03-2021 09:08 PM
Hi all,
I have no signal at home at all and so pay 20 per months for nothing. I called EE a dozen of times, they claimed to update my network settings but that didn’t help at all. So I tried to cancel the contract as EE doesn’t provide me with the service I paying for. However, the cancellation fee is around 400£, which is rather ridiculous.
I don’t usually write reviews and complaints but this time I simply don’t know what to do.
13-03-2021 09:15 PM
Have you checked the coverage in your home area ?
ee.co.uk/status
If this is ok. Could well be s problem with your phone
14-03-2021 09:11 AM - edited 14-03-2021 09:12 AM
Hi @Alisasheinkman,
Are you only experiencing this issue inside your home?
Are you using WiFi Calling?
14-03-2021 10:05 AM
The coverage & status checker includes the facility to check for, and report suspected network issues if you select "check network". I
If you're on pay-monthly with access to WiFi, you can use EE's WiFi-calling service anytime you have coverage problems, to use your phone for calls & texts as normal without any mobile network service.
14-03-2021 10:59 AM
No, sometimes in other places. It is just that it is especially frustrating to have this at home.
No, I don’t use WiFi calling.
14-03-2021 11:02 AM
“Check network” was the was thing I did. It shows excellent network where I am based so this doesn’t help.
WiFi calling doesn’t work for me
14-03-2021 11:03 AM
I did. No, other sim cards work perfectly (I have 2 for different countries). I doubt it’s IPhone 12 Pro problem.
14-03-2021 11:10 AM
Hi @Alisasheinkman,
Have you reported the issue via the coverage checker?
What happens when you try to use WiFi Calling?
14-03-2021 11:11 AM
It sounds like you're using the "check coverage" link for predicted coverage in your area.
If you use the "check network" link, this will take you to the "is there a problem" tool instead - this allows you to check for problems as well as report them.
I'm not clear from your post whether other EE users are having coverage problems in your locality, but this would be a good test of whether there is a network issue or your problems are likely to be device-related.
14-03-2021 12:04 PM
I did. Nothing happens.
same for WiFi calling
