22-10-2025
11:28 PM
- last edited on
23-10-2025
09:29 AM
lrtms
No service and ee web site says We're updating a few things right now
How am I surposed to get any help ??
Total lack of service and no customer service ..
[Mod edit: Please do not post personal information like postcode on the public board. Thanks!]
23-10-2025 08:03 AM
If you've not done so already, try toggling flight mode to ensure your phone hasn't "dropped off" available coverage.
Use the "check service status" option on https://ee.co.uk/help/mobile-coverage-checker in the first instance, to check for local service outages. The "report a problem" link should be used if no issues are reported but EE users continue to have issues.A loss of coverage will remove the ability to make/receive calls, send/receive texts or use mobile data.
If you're in the UK and have a WiFi connection, you can use WiFi-calling to keep using your phone as normal without needing network coverage.
