on 30-08-2022 07:58 PM
I have started to receive missed call information despite my phone sitting next to me and not ringing. I was waiting for an important call which never came. I contacted EE to ask if there was a problem as I cannot receive or make calls in my home, and have to go outside and face the mast before I get a signal - which is dire for want of a better word.
My signal shows no bars or just the half bar and cuts out very quickly. This has been an issue since I started my new contract. I tried to complain to EE and they informed me that there has been a problem with the Mast for several months and they cannot gain access to fix it.
The same mast transmits BT and Vodafone signals which work fine.... what is wrong with EE? I got a text to say my complaint has been resolved and closed. It has not been resolved but I cannot get any information from the EE website about making a formal complaint. It just refers me to the Ombudsman, and I'm not at that stage yet. Does anyone know how to make a complaint in writing?
on 02-09-2022 07:49 AM
Hi @Blackdog101,
I'm sorry to hear there have been some delays in accessing your local mast. In some cases we can't access mast sites without permission from the land owner. Hopefully our network team will be able to reach them soon.
on 02-09-2022 05:23 PM
@Blackdog101 wrote:
The crazy thing is, the same mast
they say is requiring fixing seems to work with other networks. I.E. BT 02,
Vodafone, sky etc. but EE have said they can’t get in touch with the
landowner to gain access to the mast. Totally confusing.
Sky is a MVNO (piggyback) provider who resell O2-coverage, but each individual network operator will have their own legal agreement & separate equipment on every shared structure.
on 02-09-2022 10:10 PM
on 02-09-2022 11:53 PM
Sky don't have their own mobile network. There are 4 mobile operators in the UK - O2, Vodafone, EE & 3. Every other provider just re-sells network coverage of one of the big-4.
You've mentioned that BT coverage is OK here - they are an EE "piggyback" in the same way as Sky is an O2-piggyback and (to give another example) Asda Mobile is a Vodafone reseller.
on 03-09-2022 09:26 PM
Hi
I have been using Wi-Fi calling and it worked for a few minutes then went back to square 1!
I have missed more calls and had to resort to providing my landline number so that I can be contacted. This is NOT good enough.! I’ve also spoken to others who informed me the landowner receives substantial subsidies for allowing the mast on their land. If this is the case, how come EE has not withheld his payments until they can access the mast?
EE informed me the problem at the mast would be repaired by 31 August. It’s now 3rd September and I’m am no closer to having a signal that I can rely on.
I have lodged a formal complaint with EE and have not received any correspondence from them apart from 2 missed calls and a text to say they’d tried to contact me. I missed the calls because I had no signal!!! To say I’m frustrated is an understatement. Why can EE not be honest and admit they either can’t fix the problem or that they can’t be bothered trying to fix it?
Meanwhile Kevin Bacon is on my TV every day telling me that EE is the most reliable network and has the best coverage in the UK. Does he know the truth? Is it another consequence of living in a rural area in NI?
on 04-09-2022 08:19 AM
Hi @Blackdog101.
Thank you for your patience with this. I've sent you a private message to get some information from you.
Please have a look and get back to me.
on 04-09-2022 08:22 AM
Does your phone show good wireless signal & WiFi-calling symbol when this problem happens? It's a very reliable service, but with two caveats:
1: It's only as good as your wireless router
2: WiFi-calling is generally designed to only kick in when your mobile coverage is deemed insufficient. Are you using Android or iOS? Recent Android phones do sometimes have an option to set "WiFi-preferred" and override any weak mobile coverage.
on 11-09-2022 02:17 AM
I've sent the information you've requested but have not had a reply.
on 11-09-2022 07:52 AM
