No mobile service in SE25
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
11-01-2025 11:27 AM
Does anyone know what is happening in the SE25 area for last few days? I have no mobile service at all or it is super slow for last 3 days.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
11-01-2025 11:47 AM
If you've not done so already, try toggling flight mode to ensure your phone hasn't "dropped off" available coverage.
Use the "check service status" option on https://ee.co.uk/help/mobile-coverage-checker in the first instance, to check for local service outages. The "report a problem" link should be used if no issues are reported but EE users continue to have issues.A loss of coverage will remove the ability to make/receive calls, send/receive texts or use mobile data.
If you're in the UK and have a WiFi connection, you can use WiFi-calling to keep using your phone as normal without needing network coverage.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
11-01-2025 11:58 AM
I've checked the status and it shows issues for the last 3 days and says "we looking into a problem in your area", but zero explanation what is going on. I don't have WiFi, I have EE sim card with unlimited data, so I can use it also as WiFi at home, and now I can't do anything. I am writing now from a o2 phone, because it is my only option to keep in touch.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
11-01-2025 12:07 PM - edited 11-01-2025 12:07 PM
There should be an option on that status check for "keep me updated". That's your best bet.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
13-01-2025 12:36 PM
Yes, I've been doing that since Wednesday, today is Monday, so it's been almost a week without any service at all or super slow,that even websites doesn't open properly. They are still "looking into a problem in the area".
I managed to contact EE on the chat, but it didn't help with anything really, they just placed a complaint in my name about it. And had just questions and advice to restart etc my phone. The phone works completely fine if I am somewhere else, but I need it to work at home.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
13-01-2025 02:51 PM
Thanks for the update here @Agnieszkarz.
I'm confident we'll get this sorted as soon as possible, but in the meantime I'd definitely recommend looking at the WiFi Calling option @bristolian mentioned in his earlier post.
This uses your home internet connection in place of the cellular signal to carry your calls and texts, but otherwise you use your phone the exact same way you always would.
Keep us posted on how you get on.
Peter
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
13-01-2025 03:02 PM
As I mentioned before, I am using the sim card as a wifi at home, I don't have broadband here, as here is no fibre connection yet, so I don't have any other option.
I'm stuck with it and I am now starting to regret I didn't go with other provider... How there can be problem for 5 days and there is zero explanation what is the reason for that and when it will be fixed?
I will try to go to EE store after work to talk to somebody, hopefully I can make it before they close... Because seriously I never had so bad experience with any broadband or mobile provider in my life.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
13-01-2025 03:03 PM
Thanks for explaining there @Agnieszkarz.
I really see where you're coming from with this one, but with network faults these can occasionally be complex and take longer than expected to resolve.
Our store should be able to help connect you with a member of our team to take a closer look into things, though.
Peter
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
13-01-2025 03:22 PM
The SIM is what allows your phone to connect to a mobile network, I think what you're saying is that your home WiFi is provided by using your phone as a hotspot.
Unfortunately, if you have all your in-home connectivity provided through a single point - and there's a fault with that point - then it stands to reason that you do lose service. All mobile networks keep downtime on the radio side to a minimum, but none will offer 24/7/365 100% uptime.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
13-01-2025 03:27 PM
I don't understand what are you saying... They offer unlimited data sim card and mobile broadband, right? I am paying for it to work.
I know there can be issues time to time, but not 5 days in a row completely nothing, zero coverage.
