No mobile data
Klaidas86
All day today no mobile data round Dungannon BT71  very disappointing as there is no information whatsoever so ever
@Klaidas86 : No data  but can you make calls & texts?
Peter_W
Welcome to the Community, @Klaidas86
It's definitely worth checking to see if your calls are working like @XRaySpeX has mentioned here.
I'd also recommend looking at the signal bars at the top of your screen to see if there's a 4G or 5G indicator at the top of the screen, or if this is showing something else.
Finally you can have a check of the area using our network status checker, which will let you know if there are any known outages in this area, and also give you the chance to report the issues you're having.
Peter
