No Service
jeyaar456
Still No Service in PH7 4EF area, yet  EE says the area has good coverage, if still a problem
EE helpfully suggests calling 150, how I do this with no service EE is less helpful.
What a shambolic company.
All mobile operators work in exactly the same way, if there's a local coverage outage.
It sounds like you're using the "check coverage" option on the service status checker. Use the "check status" option instead - this then lets you "report a problem" or "keep me posted" depending on the result.
Northerner
Hi @jeyaar456
It says;
We're having a look at PH7 4EF
We're investigating a recently reported problem. Click below and we'll update you when there's news.
