29-12-2025 09:15 PM
Both my network and data keeps dropping out on my phone showing 'emergency calls only'. There's no known issues in my area, I have tried all the 'fixes' on the website. The only one that works is resetting my phone which brings it back for a little bit then it goes again.
When it goes, I am using my phone as normal then it will go blank, lock and then it's gone.
For info - I have a Huawei P30 Pro.
29-12-2025 09:39 PM
It can often be helpful to explain what "all the fixes" includes, specifically. Otherwise no-one else knows!
If restarting your phone restores coverage, only for it to fail again subsequently, it points towards a phone fault. The screen going blank and locking seems to reinforce this. If you perform a manual network search when service has been lost, does EE show as available?
How long have you had this problem?
29-12-2025 10:54 PM
Thanks for the reply!
I think you're right, after looking into it further it seems others have had similar issues with the phone type doing the same.
It seems to be the phone no longer reading the SIM, which I'm not sure is fixable, so may be new phone time for me!
