Network down
Stev35555
I’m in south Lincolnshire, I see down for anyone else? I have no signal at all and don’t have WiFi calling.
@Stev35555  Have a look at THIS and click the check service status tab.     WiFi calling should work still even if the cellular network is down.   If WiFi calling isn’t working also it could be a SIM card fault or possibly a device fault.  Have you tried just restarting the device ?
Can you try a different EE sim in your device?  Or is anyone else with you on EE also having this same issue?
