on 23-06-2022 03:16 PM
What are the chances of getting better mobile reception at home for mobile and 4g router.
on 23-06-2022 05:33 PM
One short question, but so many directions the answer could take!
With the best will in the world, indoor coverage isn't always easy to achieve - much depends on the circumstances.
Does the coverage tool report service outdoors, and this is only an indoor problem? WiFi-calling is the recommended solution for any indoor coverage issues.
on 24-06-2022 09:22 AM
The tool shows good coverage indoors and outdoors. The problem I have is that I have to use 4g router for my internet, when I first got this 3 years ago the coverage was decent. Recently it ranges from 30gb to nothing download speed. I can walk 100 meters up the hill and get 5g on my phone. I have moved my external aerial to every part of my house looking for a better signal but nothing works, what I need is for EE to put some kind of mast between one that works and my house.
on 24-06-2022 09:28 AM
Hi @Hamster0206
Have you spoken to our Technical Support team about the problems that you've been having?
on 24-06-2022 09:29 AM
No what is their number please, or email.
on 24-06-2022 09:32 AM
If you click on the link I posted, it shows you all of the different available methods of contacting, including a live chat service, @Hamster0206.
