Mobile Signal
Gavvy
Hi
I have an issue where my signal is bad  to and from work.
The signal drops in and out I have to reconnect 6 or 7 times in a row
the signal checker doesn’t show any issues
and this has been happening for the last ax months
just wondering if anyone else has had this problem
Are you saying that coverage is coming & going whilst in the exact same spot? Or when you are travelling? And if the latter, is it always in the same location?
If you have problems in one (or several) specific locations, I'd recommend using the "report a problem" link on the status tool.
