Lost 4G
Abennett205
Hi.  A week ago I lost my 4G signal on a Huawei P20 Pro and despite having travelled in different areas it is still missing. Occasionally, there is a very weak sign of 4G but nothing usable.   Tried all the usual fixes (on/off, aeroplane mode on/off etc etc) but to no avail.  Heading abroad on Sunday and need a signal before then.  HELP please!
Leanne_T
Let me know how you get on @Abennett205
Leanne 🙂
9 REPLIES 9
EssexBoyEE
The P20 Pro are Dual Sim Phones, make sure the settings for Preferred Network (Something like 2G/3G/4G(LTE) is set to preferred for the correct Sim Slot.
Unfortunately, the preferred network mode cannot be changed from 4G/3G/2G/auto
Thanks anyway.
It will be under Network Settings, if Dual SIM under each SIM Settings, 2, 3G or 2,3,4G Auto, it's a Battery Saving feature.
On some older Huawei Dual Sims the 4G only worked on one of the SIM Slots, Default was SIM 1 unless changed.
Another thing to check is the APN is correct, again for each SIM.
Does it let you do *#*#4636#*#* to get to Phone info?
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
Just a single SIM and that combo of symbols yields no result
Thanks again
Sent from my Huawei phone
Leanne_T
Hi @Abennett205
Can you make and receive calls?
Are you able to try the SIM card in another phone to see if you have 4G signal?
Leanne 🙂
Yes I have and it works fine, so it has to be the phone. Have an appointment at EE shop this afternoon.
Thanks for your help.
Leanne_T
Leanne 🙂
Abennett205
I visited the EE store in Braehead and a very helpful young man thought it was a SIM card issue.  The card was scratched, so he replaced it and 4G signal started to come back while I was away on holiday in Croatia. However, biggest improvement seemed to be when Huawei did a system update on my phone a few days ago. All good now, so either SIM or system update requirement was the issue.
Thanks everyone for suggestions
Leanne_T
Really pleased to hear this is sorted now for you @Abennett205
Thanks for coming back and letting us know 🙂
