on 15-06-2022 12:01 PM
As many now know, EE are discontinuing the service of their excellent 3G Booster box, and after 7 fabulous years of 5 bar coverage use, I got 3 weeks notice of this. My phone does NOT have WiFi calling option, so I'm a bit snookered. I don't want to buy a new phone, current one is working perfectly, besides, think of all the poor dolphins in throwing perfectly good stuff in the bin unnecessarily!
Is anyone aware if there is a 4G 'booster box' available that will work for me, preferably supplied by EE? (or a generic one as an alternative)
on 16-06-2022 04:18 PM
@wardi wrote:@stephen5000 .. if it helps I have a Galaxy S10 plus which definitely does WiFi calling. The other S10 variants also offer it. These phones are 2-3 years old now but available refurbished from approx £175-£325. Very nice phones in other respects too. I got mine refurbished from Qwik Phone and it looked like new on arrival.
Any further recommendations (used/refurbished) up to maximum of £100 much appreciated - I simply can't afford anything more.
on 16-06-2022 05:50 PM
@stephen5000 wrote:
@nosignalbox wrote:
Other family members iPhone WiFi calling working fine.Much as I despise Apple, all their phones appear to be WiFi calling compliant - shame Android is hit & miss...
SIM-free Android support for VoLTE (4G-calling) and VoWiFi (WiFi-calling) is hugely improved on the situation a couple of years ago.
16-06-2022 06:59 PM - edited 16-06-2022 07:08 PM
@bristolian wrote:
Sadly, you have hit my stumbling block LOL With my budget, I am looking at phones 2 to 3 years old, and as you say, WiFi calling doesn't seem to have been invented then 😁
An analogy would be forcing someone to buy a battery car when you know they are not suitable for your needs, far too expensive, and no infrastructure yet to run one LOL
on 16-06-2022 07:56 PM
An analogy would be making your local roads only accessible to more modern vehicles, but that's a common complaint with clean-air-zones all over the country.
In the case of mobile networks, blanket indoor coverage is nigh-on impossible to achieve - and as the 3G network is switched off, WiFi-calling - along with low-band 800Mhz coverage - are much better solutions for these scenarios.
on 16-06-2022 09:02 PM
So EE tell me that I cannot use the OnePlus,3t even though it does have WiFi calling.
They say only 6t and above supported.
So I have to get a new phone as I have been made isolated and vulnerable with the switching off of signal box in my area with no mobile network coverage inside or out.☹️
Before I spend can you confirm if Motorola G30 will work on WiFi calling with EE?
on 18-06-2022 06:20 PM
Shopping for a replacement phone is depressing! Maybe I'm just doing it wrong!
Can anyone tell me what I need to look at in a phones spec that will tell me if it is capable of, 'WiFi calling'? Looking at a Samsung Galaxy A41 - but the terminology of 'WiFi calling' doesn't exist on any review/spec I read on the phone, so is there a secret tech term I need to look out for?
on 18-06-2022 06:39 PM
The Galaxy A41 should be fine for both WiFi-calling & 4G-calling.
EE will only provide support if you purchase the phone from them, but a SIM-free model should be fine.
You'd be wise to consider the two alternative ways of buying products in the UK:
1: Online or telesales come with a statutory 14days "change of mind" right of return, so if the product doesn't work for you, it can be returned.
2: Instore purchases don't have this and returns are at the retailer's discretion - so if any specific feature is important for you, check it before buying.
For this reason alone, I would recommend an online or telesales purchase in this situation.
on 18-06-2022 06:44 PM
Thank you for quick response. Is there a 'secret' term I should look out for to be certain of WiFi Calling? Haven't totally settled on the Samsung yet and am still trying to check out alternatives...
on 18-06-2022 07:47 PM
I ended up reluctantly buying a Samsung Galaxy A13 for £129 - it wasn't easy to find out how, but it does do wifi calling and works in my home.
Pain in the **bleep** to set up and although 99% OK it won't work with my Chase banking app (my ancient phone did)- confirmed not compatible by Chase themselves!
I remain unhappy with EE for forcing this change on me without any notification
on 18-06-2022 08:06 PM
Samsung A41 on hold LOL Just discovered it doesn't have a notification LED. Like having a car with no oil light, just don't understand phone manufacturers at all, they're obviously all young geeks with no real life experience doing a bit of design in between playing with their X box!
