18-08-2025 10:58 PM
I always have issues using EE network outside it doesn’t work properly I only enjoy internet when I’m connected to a wifi
19-08-2025 09:30 AM
Hi @Ayo11
Welcome to the community. We'll do our best to help you.
What kind of device are you using? Does it work at all for mobile data, even if sporadically?
19-08-2025 09:57 AM
Yes I have an iPhone 12 Pro Max
19-08-2025 10:35 AM
Is 'mobile data' switched on in your phone settings, @Ayo11?
It should be under Settings > Mobile Service > Mobile Data > On.
19-08-2025 10:40 AM
Yes it’s always on
19-08-2025 10:45 AM
That's good, @Ayo11. Just checking.
Is there a particular area where you notice the problem? It may be worth checking a couple of areas on our network status checker to see if we're aware of any maintenance works in your area.
