I can’t make any calls
Mich0002
Is anyone else having issues making calls now? It doesn’t even ring the calls are just dropping straight away - any number I try
@Mich0002   Have a look at THIS fill it out and click the check status tab.  If there is a known issue that will show it, or you could report an issue yourself.   Is anyone with you on EE having this issue?
