01-04-2024 06:36 PM
We have been coming to same campsite in North Wales LL54 7YY for last 10 years and have enjoyed using EE mobile data & calls without any problems. Arriving this March 2024 we now no longer have an EE signal other than an occasional 4G which appears for a minute then disappears again. Why has signal suddenly disappeared? Other people on campsite have also experienced this. Coverage map indicates good signal but in reality there is none.
O2 seems to work fine.
02-04-2024 07:52 AM
Hello @RosM.
Thanks for coming here.
When using the Network Checker are you seeing any known problems?
Are you aware of other people experiencing this to?
Katie
02-04-2024 07:57 AM
No problems show on Network Checker.
Several other people I’ve spoken to are also experiencing same problem. I believe one person has reported issue but no improvement yet.
02-04-2024 08:26 AM
Were you able to report a problem on the status checker, @RosM?
02-04-2024 11:34 AM
No. Didn’t have enough signal.
02-04-2024 12:13 PM
Could you give it a try when connected to WiFi please, @RosM?
02-04-2024 01:43 PM
I’ve managed to log onto campsite WiFi & reported problem. However the network checker still says good network connection - but there isn’t!
03-04-2024 09:02 AM
After reporting problem about LL54 7YY (campsite where the problem is) I’ve since received EE text saying they are investigating the problem but at my home postcode !! Where my EE contract is registered. Obviously reported problem was not read. I had clearly stated that the lack of reception was in North Wales area not at home.
03-04-2024 07:25 PM
I’ve now received a text message from EE so they are aware of the problem. See below:-
MyPlace update: There is a problem near Betws Garmon which is taking longer than expected to resolve. We will continue to keep you updated. To keep connected simply use WIFI calling, to get started click here ee.co.uk/wifi-calling. To manage your MyPlaces updates, go to coverage.ee.co.uk To opt out of all MyPlaces updates, text STOP to 444.
