Connection problems
Naween
I don’t have signal in my house
Is this a recent problem - have you had coverage in your house previously?
If you're in the UK and have a WiFi connection, you can use WiFi-calling to keep using your phone as normal without needing network coverage.
I don’t no because this is my new house. How can I fix it
Did you have indoor coverage when you first viewed your new property? Do you have coverage outdoors? Do you have a working WiFi hotspot indoors?
Unless there's a local fault causing a loss of service, the coverage levels are what they are. Check your coverage levels using the online checker at https://ee.co.uk/help/mobile-coverage-checker
"Check coverage" predicts the normal level of service in your chosen location
"Check service status" searches for known issues in your locality.
No 4g / 5g signal only normal call please help me
Rach_H
Hi @Naween,
Welcome to the Community!
I'm sorry to hear about the trouble you're having. Have you been able to check the service status as @bristolian has mentioned above, to see if this is the anticipated coverage, or if there is any work happening nearby?
Rach
