5g
frankie1982
Evening, has anyone else had issues with 5g dropping out tonight and last night from around 8pm in the ruislip area?
Ali_A
Hi @frankie1982
Sorry to hear you’re facing problems with signal.
The first step to try is restarting your device.  It's great that you have asked here, but do you know if anyone else on EE is facing the same issue?
You can check coverage and network status at Check mobile coverage where you can also report any issues you are facing, as well as sign up for updates on any known issues that may be going on.
Ali
