5G Sim upgrade
Coombsd
I've been on the same SIM plan for a few years now and I'm looking to upgrade from 4G to 5G.
Can my current SIM be upgraded on my current plan, or do I have to move to a totally new SIM/Plan?
Thanks!
All of EE's SIMS are multi-technology and support every "G". There is an issue with SIMs from before approx 2021, that only support 5G in NSA mode.
EE-CS should be able to check your SIM profile if necessary, or it's easily resolved if you do change to a 5G plan and find yourself unable to use VoNR and.or 5GSA. This is marketed as 5G+
