4GEE Mini will not connect to Mustang Mach E
Laika
Valued Contributor
Valued Contributor
EE just upgraded my old in car WiFi device from, I think it was called a Buzz and went in the 12v lighter hole, to a 4GEE Mini.
all my devices connect fine but the car, which did connect to the old thing, will not.  I have looked at the Mach E forums and they talk of similar problems with other networks but are talking about DNS settings. There are very limited amount of settings on the 4GEE Mini and I have tried everything from WAP2 to WAP/WAP2, 2.5 to 5, security etc but my car just says unable to connect. If I put in the wrong password the car says it’s the wrong password so I know it’s talking.
Any thoughts?
20 REPLIES 20
Jon_K
Former EE Employee
Hi @Laika.
How does the new device connect to the car?
Is it plugged in or through something else like Bluetooth?
Jon
Laika
Valued Contributor
Valued Contributor
Jon,
It has a modem and connects via WiFi. I can connect the car to the house wifi network and I can also connect to my phone via hotspot. It also connected ok to the Buzzard with the EE sim. It’s just the new Mini that it refuses to connect to.
I select wifi networks in settings on the car and enter the password.
Regards,
Sean Byrne
Jon_K
Former EE Employee
Thanks @Laika.
Do you get an error message when you try to connect the car and the WiFi device?
Jon
Laika
Valued Contributor
Valued Contributor
on,
No real error message just “Sync was not able to connect to 4GEE Mini”. That’s after i put the password in. If I put the incorrect password it says it’s the wrong password.
Regards,
Sean Byrne
Christopher_G
Could you try forgetting all of your connections and re-setting them up from scratch, @Laika?
Laika
Valued Contributor
Valued Contributor
Tried that. No go.
Regards,
xxxx xxxxx
[Mod edit: Please do not post personal information on the public board. Thanks!]
Jon_K
Former EE Employee
Thanks @Laika.
Other than completely resetting the new device and trying again, the best ting to do would be to get in touch with our Tech Gurus.
They will be able to run through advanced troubleshooting steps with you to try and get this connected.
Jon
Laika
Valued Contributor
Valued Contributor
Thanks Jon.
How do I get in touch with the Guru’s?
Regards,
xxxx xxxxx
Leanne_T
Hi @Laika
If you call us on 0800 079 8586 the team will be happy to help you get this looked into 🙂
