07-05-2025 11:04 AM
Hello,
I will be purchasing a Vivo x200 Ultra which runs on a Chinese ROM with Google services and am looking to switch to EE Sim only shortly. Can anyone confirm if the phone will work on EE with the confirmed network band support below:
4G: TD-LTE : B34/B38/B39/B40/B41/B42/B43/B48
FDD-LTE : B1/B2/B3/B4/B5/B7/B8/B12/B17/B18/B19/B20/B25/B26/B28/B66
5G: n1/n2/n3/n5/n7/n8/n12/n18/n20/n25/n26/n28/n38/n40/n41/n48/n66/n77/
thanks
07-05-2025 02:27 PM
Hi @VoidZ
We use LTE - B1, B3, B7, B20
And 5G - N1, N3, N7, N28 and N78
So it looks like the device would cover 5G, but not 4G.
Hope this helps.
Ali
07-05-2025 02:43 PM
Thanks for the quick reply Ali!
Please correct me if I'm wrong, but with modern day chipsets in phones, do they not offer compatibility amongst different variations of LTE bandwidths? As you mentioned some of the bands that are in my post I was assuming that the phone would support 4G but I am not sure.
Hopefully my message makes sense haha
07-05-2025 02:45 PM - edited 07-05-2025 02:58 PM
EE's base 4G layer is B3-1800Mhz. B1 & B7 are used as capacity layers, B20 is an "extended range" coverage layer for remote & indoor coverage enhancement in many (but not all) locations, alongside some very localised B28.
Unless you're using 5G-SA, your phone will still be using 4G-LTE as an anchor layer.
07-05-2025 02:51 PM
Thank you!
Suppose I best do some more research into a couple more mobile brands then if EE is not to be recommended. I'm not after very fast speeds but just enough to do casual things such as browse social media, listen to music etc.
07-05-2025 03:00 PM
What do you mean by "variations of LTE bandwidths"?
Frequency band support is part of the hardware, there will be different configurations of EARFCN (carrier-ID) within each band.
For example, B3-1800Mhz has 5Mhz, 10Mhz & 20Mhz carriers within the band.
07-05-2025 03:28 PM
You're welcome @VoidZ
As @bristolian  mentioned, the bands can't be read by the chips if the hardware is not there.
Hopefully you'll find the right device that matches your needs!
Ali
07-05-2025 03:36 PM - edited 07-05-2025 03:37 PM
Correct, but to quote the OP...
FDD-LTE : B1/B2/B3/B4/B5/B7/B8/B12/B17/B18/B19/B20/B25/B26/B28/B66 (the bold doesn't highlight well)
VoLTE support is the other issue, especially on B20 & B28, B3 just relies on CSFB to 2G1800.
08-05-2025 08:55 PM
From what I've gathered then is essentially 4G/5G wise it will work as intended however for taking calls it might lack and drop back to 2G/3G connections which can potentially cause calls to drop as the x200 Ultra might not support VoLTE. I dont really make calls much at all and if I do its usually on a social media platform i.e WhatsApp or Discord.
08-05-2025 10:30 PM
The spec you've described appears to have the correct frequency-band support for EE-UK. EE don't operate a 3G network, so without VoLTE support all your calls will be over 2G.
Anything beyond that can only be properly ascertained by testing it.
