07-09-2025 03:43 PM
Who the hell are 1&1 Versatel? I have recently had a major drop in speed using these people, it only seems to be where I live, just down the road I can connect to EE which gives better speeds
07-09-2025 03:52 PM
Hi @stevemartin
https://www.united-internet.de/en/brands/11-versatel.html
Search Google.
Might be used by BT for some infrastructure maybe?
07-09-2025 04:06 PM
How are you using 1&1 Versatel? Are you in Germany? It is a German fixed fibre BB provider. How can it affect EE's mobile network?
07-09-2025 04:07 PM
What makes you think you are "using" 1&1? What are you doing with your phone, what is your phone saying/telling you, that is causing you to think so?
Are you running a speed-test and it's being presented as the server location?
07-09-2025 04:26 PM
1&1 (aka IONOS) itself would be a diff matter. It is a global domain & email provider amongst probably other things incl. a World Tour Cycling Team.
08-09-2025 02:21 PM
When I do a speedtest on ookla the server name comes up as 1&!Versatel instead of EE, I have just bought a Pixel 10 pro would that make any difference?
08-09-2025 02:27 PM - edited 08-09-2025 02:39 PM
All speedtests use their own collection of servers which are never EE's but various Internet providers.
All you have done is run a speedtest to a default server in Germany. No wonder you are getting slow speeds to Germany. You should get the speedtest to use a server nearer yourself in UK. There should be some button to Change Server, viz:
08-09-2025 04:20 PM
Ookla speed-test should have the option of using whichever server is best performing at the time of running the test.
