how to use I phone abroad without using data
SylviaEldred
If you disable the "use mobile data" & "data roaming" options in your phone's menu, you will be able to make & receive calls & send/receive texts.
If you are on contract, remember to text ROAMING to 150 before you leave UK to ensure the roaming ability is enabled on your account.
If you are on PAYG, make sure you have already used your PAYG SIM to make a call or text in the UK.
