on 05-12-2022 08:29 PM
Hi folks.
I am currently experiencing an issue with my mobile data. I got the text saying my data has run out, and i need to buy more.However the page it normally takes me to when i press the link in the text just times out, with an error saying connection aborted. I also cannot load the my EE app, it just sits doing nothing. If i try it with wifi on it just says something went wrong.
Any ideas?
Bov
Solved! Go to Solution.
on 07-12-2022 01:38 PM
Look at http://add-on.ee.co.uk/purchase when not connected to WiFi to see what data add-ons are available. Make sure you use HTTP:, not HTTPS: & do it under IE, FF or Samsung Internet not Chrome or any browser that forces HTTPS:.
on 06-12-2022 08:24 AM
Hi @Bovrinox
Welcome to the community.
Is it this add-on status page that you're accessing? Could you try on a different or browser please?
on 07-12-2022 06:05 AM
on 07-12-2022 09:27 AM
OK, thanks for trying that, @Bovrinox.
I think it will be best for you to speak to our Mobile Care team so they can look into this for you.
Let us know how you get on.
on 07-12-2022 06:44 PM
Oh man, you nailed it! That worked perfectly, thank you so much!
on 07-12-2022 07:24 PM
