WiFi hotsopt
Dave1875
Hi all, anyone here know how to connect to WiFi hot-spot?
lamb0
Hi Dave ive not done this for a while but someone has to enable hotspot on their phone and then when you search for wifi connection his phone/hotspot should show up. Im not to sure on this but I dont this you need a pass key unless he has specifically selected one. You should now be able to select his phone and tht is it.
Leanne_T
Hi @Dave1875
What device are you using?
Are you wanting to connect to another device's hotspot, or use yours as a hotspot?
354-
Star Contributor
Star Contributor
If the café/bar you're in offers a WiFi hotspot, you ask at the counter or look on the walls for its pwd & connect your device to their WiFi network supplying the pwd.
