on 29-01-2024 09:34 PM
Just recently in areas where I used to get Internet access using mobile data I can't now??? It's happening a lot
on 29-01-2024 10:32 PM
Can you quantify "recently"? Are you across mid/west-Wales, the Midlands or Norfolk/East Angllia?
Do you have a 4G phone or a 3G one? Are you able to make & receive calls OK?
on 29-01-2024 10:45 PM
on 29-01-2024 10:53 PM
Can you quantify "recently" when these symptoms started?
Ensure that mobile data is enabled, and check whether symptoms persist after toggling flight mode. Does VoLTE (Android) or 4G-calling (Apple) show on-screen next to your coverage indicators?
on 30-01-2024 05:25 AM
on 30-01-2024 07:53 AM
on 30-01-2024 07:56 AM
on 30-01-2024 07:57 AM
What type of plan are you using, @Jay351?
Is it pay as you go or pay monthly?
Is it a 3G plan?
on 30-01-2024 08:03 AM
It sounds like you have disabled 4G in your phone, and you may be in an area where 3G has now been switched off. Meaning your phone has fallen back to 2G which explains your symptoms.
There are two options you should change in your phone's settings.
1: Under network connections, ensure 4G/LTE is enabled.
2: Under the phone settings, ensure VoLTE is enabled.
These two options will put the phone back onto the 4G network and rectify your symptoms.
