Usa data roaming
Hamiltonboots
In th USA at the moment but cannot get mobile data to work.  Purchsed the roaming pack before leaving UK and had text when landed to say roaming enabled. Purchased an additional 4g data before coming away.  Reset all settings and restarted phone but as soon as WiFi is turned off I get no Internet - please help
Can you make calls & texts?
As  you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on your a/c.
