Travel data pass
Lbrooke69
My son is in Dubai his data pass should have been activated but after calling EE wasn’t so has been updated while he is away .
he can still not connect to a network he has tried manually but nothing works .
does it take24 hours  to work or should it be immediate
If you now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
