Sky betting app
Mickeyvandeven
I recently have been unable to load the sky bet app when im away from my house I've checked that the location function is on and have gone through all suggestions to fix problem ( uninstall and reinstall,  clear cache , turn device on / off etc but nothing seems to be working any ideas ?
So I went into settings clicked on apps and found sky bet app , clicked it
and cleared cache and mobile data then turned device off then on and i was
then able to use it , hope this works for you .
@Mickeyvandeven It could be Switching Content Lock OFF or ON . It is switched on on new & upgraded contracts & seems to affect adult & social sites. If just switching it OFF doesn't help, try switching it to STRICT, reboot your device and then switching it to OFF. That is seeming to do the trick.
Thanks for your help I'll give it a go .
I have the same problem and none of the above has worked to fix my problem either
