17-01-2023 08:23 PM
Hi guys
having problems with getting the sim to enable in my Vehicle Mobile digital Video recorder
Camera system works great but I’m unable to get it online sim works fine in a mobile but I’m concerned about APN set up I’m not sure what the access number will be I have used the EE settings please can anyone help
17-01-2023 10:34 PM
You have it in front of you. The Username/pwd for an EE SIM is "eesecure"/"secure".
18-01-2023 07:24 AM
Hi XRay
Yes I’ve inputted those but
its the access number I’m after please see picture
18-01-2023 12:14 PM - edited 18-01-2023 12:15 PM
But that's showing "card"/"***", not the required "eesecure"/"secure". Hence it doesn't work.
You need to create a New APN with "eesecure"/"secure" & then make it Default. Access No. ="*99#" is correct.
18-01-2023 04:02 PM
Hi X-ray
sorry for being miss leading I had sent you screen shot of default setting I had logged in manually and changed username & passwords but even using *99# is would not go online
I’m going to reset to default later once I’m home and reload
thanks for your input
18-01-2023 04:52 PM
Yes, you don't that as the Default. You want to make the APN with "eesecure"/"secure" as the Default.
