Roaming
Agafonova
Hello.
I am abroad at the moment. Using 10£ monthly roaming. And my mobile data suddenly stopped to work. However,  Im checking data and I still have plenty left. All settings set for using it.
 Can you please advise me.
Jon_K
Former EE Employee
Hi @Agafonova
Where are you currently?
What phone are you using?
Can you try restarting your phone?
Jon
The £10 monthly roaming you refer to is just a billing add-on, it has no effect on your phone's ability to roam on foreign networks.
Does your phone show coverage of a network in the country you're in? Can you make & receive calls OK? A common fix for roaming problems is to manually switch to an alternative network.
