on 12-02-2024 01:52 PM
I just ported my line and I am facing the same issue. It shows 5g and no internet. I go indoos and is bye to the internet. I never faced that on my old line.
on 12-02-2024 02:22 PM
Hello @Tj671.
Welcome to the community.
Has your number port only completed today?
What does coverage show at your location for indoor and outdoor? this can be checked using the Network Status Checker.
Katie
on 12-02-2024 04:22 PM
on 12-02-2024 05:02 PM
Hi @Tj671
Can you access data in any other area?
What happens if you try and access the internet or any apps?
Thanks.
Leanne 🙂
on 12-02-2024 07:23 PM
on 13-02-2024 07:59 AM
Hi @Tj671,
If you are experiencing this problem in all buildings, rather than in an isolated area, there may be an issue with your device.
Please get in touch with Technical Support on 150 so a member of the team can run through some diagnostics with you.
They'll be happy to help. 🙂
