15-05-2026 03:17 PM
I have a business plan which include international roaming. I am currently in the IS and I have no data and cannot make calls. I can’t even call the EE help number as it says it is blocked. I am here for work and need my phone to actually do its job! There is no online help or any way of contacting without “call us”.
15-05-2026 03:26 PM
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 9566000 using a web-calling app over WiFi. The myEE app has a live-chat facility which may be another option.
