on 04-12-2025 07:21 PM
We have been experiencing poor 5G speed for the past 3 weeks. EE technical help are not much use, they make out they have done something or they know when the issue will be fixed. Yet it always reverts to the same lucky to get 0.5 Mbps after 17:00 each day. During the day 10Mbps if you are lucky. Network issues on the web or the app doesn’t work. Has anyone else experienced the same thing. Will be looking to leave EE if not sorted soon. Thanks
on 04-12-2025 07:58 PM
Are you saying that data speeds are varying during the day? On the face of it, that's likely to be a capacity issue - although there's some aspects that are not entirely clear from your post.
Prior to this 3week "cliff edge", were speeds noticeably better than what you describe? Can you quantify them?
It would be unusual for congestion issues to occur so suddenly, which lends weight to a combination of factors being at play.
on 06-12-2025 06:39 AM
on 06-12-2025 10:37 AM
@Blackdog73 wrote:
We have contacted EE Technical help many times, but they don't say whether there's a network issue, and they never resolve the problem.
Raising network issues with CS is exactly the right thing to do - what have they offered thus far by means of further investigation or next steps?
Your first post alluded to this problem having occurred in the past 3 weeks, you've now mentioned this being a longer-term issue.
