Mobie data
Drewt08
Recently my phone has been extremely laggy on wifi and my data will not work outside the house I’ve reset the wifi router several times and even when I have good signal my data will not work I just wanted to know if this had happened to anyone else and how they fixed it?
6 REPLIES 6
Do you have any other devices connected to the same router, such as laptops or tablets? If so, are they similarly affected?
How long as your mobile data not worked for? Do you have mobile data enabled on your phone?
Yes there are tv laptops and games consoles connected to the wifi
my data hasn’t been working outside the house since before Christmas now I thought it was a temporary issue
Christopher_G
Are the other connections laggy too, or is it just your phone, @Drewt08?
What kind of phone are you using?
Which router do you have? Why do you expect to connect to it away from your house? They have limited range.
iPhone 11 Pro max
Katie_J
Hi @Tugay
Thanks for coming here.
Are you experiencing issues with your iPhone 11 Pro Max whilst connected to WiFi?
Katie
