27-08-2025 09:30 AM - last edited on 27-08-2025 11:44 AM by Peter_W
Can’t get internet only one bar
27-08-2025 12:11 PM
"Only one bar" should not, of itself, be a problem - it's coverage.
Can you make & receive calls? Have you been able to use data at this location previously?
27-08-2025 02:17 PM
Hey @Lily1967.
Welcome to the EE Community!
I've just split your comment into its own thread so we can make sure all the info you're getting is relevant for you.
Like @bristolian has mentioned, having one bar won't necessarily affect your ability to connect to data.
If you haven't already I'd recommend giving your phone a restart, as occasionally the connection can 'get stuck' and prevent you getting online.
It's also worth taking a look at our network status checker to see if anything is reported in the area, too.
Peter
